20 Most Recent Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Questions & Answers
repair the main board
Maytag 24"... | Answered on Apr 23, 2017
you have a bad oven temp sensor probe
Maytag 24"... | Answered on Jan 18, 2017
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Maytag 24"... | Answered on Dec 25, 2013
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Maytag 24"... | Answered on Jun 21, 2011
Hi dpaulthomas,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to resolve this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Hi amarcey,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Hi mil4kids,
F2 means the oven temperature is too hot. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Hi angelice_wil,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
62 questions posted
Top Maytag Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
gas oven electric pilot light doesnt
  • Ovens
