HP Compaq Presario CQ60Z Notebook Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a slimtype dvd a ds8a2s a ata device that I get a code 10 device cannot start message in device manager I have tried to re-install the driver and downloaded any updated drivers and get same message
Jaipal Reddy
Level 2:
Novelist:
  • Expert 130 Answers
  • Posted on Jan 13, 2010
Jaipal Reddy
Expert
Level 2:
Novelist:
Answers
130
Questions
0
Helped
101550
Points
327
From your description I understand that the DVD drive is not working and you have code 10 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Apr 26, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
5436
Points
38
Go into device manager and right click the drive and click uninstall driver and click ok. After its done click the check hardware icon and let the computer find and reinstall the drive and you should be good as new
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2908
Points
I have a slimtype dvd a ds8a2s a ata device that I get a code 19 device cannot start message in device manager, what do i do?? help please.
12helpful
2answers
I have Slimtype dvd A DS8A2S ata Device and windows cannot load the driver for this hardware.the driver may be corrupted or missing (code 39).What should I do to fix this problem?
1.Click on Start.
2.In Start Search or Run type devmgmt.msc and then hit enter.
3.This would open the Device Manager Window.
4.Now locate something which reads as Cd/DVD , there would be a + sign next to it,
5.Click on the +Sign next to it and down below locate the driver responsible for the funtioning of the cd & dvd.
6.Now right click on the driver and then click on Uninstall.
7.Now locate an option right at the top which reads as ACTIONS.
8.Click on Actions and then click on Scan for Hardware Changes.
9.Close the Device Maneger Window.
10.Click on Start and in Start Search type Regedit and then click Enter.
11.This would open the Registry Editor Window.
12.Locate an option which reads as HKEY_LOCAL_MACHINE
13.Click on the +Sign next to it.
14.Now locate another option which reads as SYSTEM.
15.Click on the +Sign next to SYSTEM.
16.Now Locate another option which reads as Current Control Set.
17.Click on the +Sign next to it.
18.Now locate another option which reads as CONTROL.
19.Click on the +Sign next to it.
20.Locate an option reading as CLASS.
21.Click on the +Sign next to it.
22.Now we would find a lot of keys..
23.Locate a key which reads as 4D36E965
24.Click on the Key and then look right at the right top corner of the screen and locate Upper Filters and Lower Filters.
25.Right click on Upper Filter and then click on Delete.
26.Do the same if you get Lower Filters as well.
27.CLose the registry and restart the computer to check rthe funtionality of the Drive.
I am sharing a screenshot of how filters look in registry..
http://filedb.experts-exchange.com/incoming/2008/06_w26/35425/Regedit-DVD.JPG
Hope this works.
Plz rate if helpful
Regards
Ken
1helpful
I have Slimtype DVD A DS8A2S ATA Device and windows cannot load the driver for this hardware.The driver may be corrupted or missing (code 39).What should I do to fix this problem?
If you don't have a disk for the drive you'll need to go to the manufactures web site and download the proper driver for the drive. You then need to install the driver according to the manufactures instruction, after that windows should be able to load your driver.
2helpful
Fist, go to devise mgr, --start button, in search area type devise,
find the devise, it should have a yellow shield, click on expand so you see the actual drive, it could be open with the shield next to it already.
It will be under cd roms. right click on it and choose uninstall, yes
uninstall the devise, now cold boot , shut down the computer and restart
it and wait until windows says found new hardware, if it doesn't throw the error when installing or after installing, go back and check it for the yellow shield.
Drive needed for my dvd drive(Slimtype DVD A DS8A1H ATA Device)
Here is a link to all your drivers you can try reinstalling it from here, click here for page. hope this helps
2answers
I am not able to use my DVD drive because the driver is corrupt. It is the Slimtype DVD DS8A2S-A ATA. It came with my Compaq HP. So, far I can't repair it or find a replacement for it.
fmoise914,
Your DVD is fine!!!. It is the driver that needs changing. Have you googled your Hp device? Usually when you google your device as "Slimtype DVD DS8A25-A Driver" You should see Hp site with drivers.Try that out!
2helpful
Slimline DVD Burner
Go to the device manager. uninstall the dvd drive .restart computer after turning the power off. re-install the device from add hardware wizard.restart computer.this may solve the problem.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
