If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
My maxtor external hard drive has stopped working.There is a chance that you can recover data using a USB to IDE or SATA Adapter Cable to recover your data they cost about $30 if you cant get hard drive to power with adapter chances are it has crashed there are places that can get data off hard drive but they are very pricey hope this helps.
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable. It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
What I do know in reference to your question. I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port. [ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp. Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive. Or am I missing the point somewhere?
For Maxtor Basics and Personal Storage 3100 and 3200 drives, there may or may not be an LED on the power supply, but the light on the drive should usually remain solid during normal operation, while powered on.
1. But if the power supply does have an LED on it, isolate the problem by connecting the power supply into a power outlet without the hard drive connected to it. If the LED blinks in this configuration, the power supply is faulty. Please contact Technical Support for replacement information.
2. If the LED remains solid, connect the drive. Once it is connected, turn the drive on. If the LED begins blinking, the drive has an electronic failure. Please replace the drive. You can create a warranty replacement order to replace the unit.
From what you have said i'm afraid it sounds like there is an electronic failure of the drive. I haven't followed the process through but they do offer a Data Recovery Service at :-
https://services.seagate.com/index.aspx?lng=en-us
There is an online form to fill in or you can telephone 020 7432 4619 to talk to a Data Recovery specialist.
I hope this helps and I hope that you can recover your pictures and videos. Mark.
When a file is delete, it's still there on the drive, just as before; all that happens is that the file table marks it as free space and changes its name so it's no longer visible. There are a number of "undelete" utilities available, including several good ones, like asoftech data recovery that helped me before: http://www.asoftech.com/adr/
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
The HDD is corrupt.Try to re-format if you get your PC to open.
All data will be lost.
To be honest with you,I would not now trust the HDD for any critical or confidential data.
