When I plug my SVP MP300 into my computer it says there was a malfunction and it doesn't recognize the device.
SOURCE: Computer does not recognize Portable Harddrive
restart you system then plug it into different port if still not working then change the wire of ur hardrive...
Plz dont forget to rate
Testimonial: "It was great to get a advice right away! Thanks! I'll get another cable to try if it works. "
SOURCE: Usb device is not recognized it has malfunctioned i get this msg when i start my computer
Change your USB cable.
SOURCE: Device has malfunctioned and Windows does not recognize it.
Hi
i m having the problem with my USB while connecting the my mobile (USB Port) i m getting the following message
"problem attached to this computer has malfunctioned and windows does not recognize it "
Please help me, how to resolve the my problem ?
Thanks n Regards
Srinivas.T
SOURCE: USB DEVICE NOT RECOGNIZED KODAK EASYSHARE C913
remove you memory card
turn camera ON > Press Menu > go to setup menu> format internal memory>
take 1-2 picture > reconnect your camera to the computer>
if the camera will be recognized> reinsert the MMC> format the MMC > it will delete all your pictures including the corrupted ones
most of the time its just a MMC issue
good luck
SOURCE: I have a svp mp300 media box. When i plug the
I had the same problem and finally figured out that the music was going to the device, but it was not under the mp3 file. If you go to 'computer', then click on the drive you have it plugged into you can drag the files into the mp3 file.
