Question about SVP Aqua 5500 18mp Underwater Digital Cameravideo W/dual Lcd Screens Waterproof
Manual for the SVP Aqua 5500
Need to introduce SD card
Posted by David Pazoff on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SVP Master
  • 102,366 Answers
You may download a copy of the manual here.
Posted on Feb 25, 2013
Eva M Merrill
    New Friend:
How do we download our photos onto the computer?
Posted on Dec 22, 2016
I have a wild game card reader and it will not let me look at my pics and keeps turning off and coming back on. How do I fix this
Just a WILD guess: Might be a problem with your external SD or micro SD card . If it's a micro SD, you can introduce it in a USB microSD card reader and check it in your computer. It should show as a Removable disk..
You even might try replacing this SD card
Else, no idea, worst case "scenario", might be the electronics of your camera
Sep 03, 2015 | Cameras
I bought a used jazz ultratab c855 dose not have SD card tryed to use one I had here and it Won,t work do I need to buy a special card or can I format one to work ?
Your jazz ultratab c855 should work with SD up to 32 Gb; are you sure that the card you have is good ?
You can test it introducing it in a MicriSD Reader and check it in any computer. If shows up as Removable Drive with correct size, your card is good.
Jun 20, 2015 | Jazz Cameras
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Feb 21, 2015 | Samsung Digimax S800 Digital Camera
I am having problems introducing the SD card into my SVP Aqua 5500
The camera takes microSD cards. Open the battery door to uncover the slot.
Feb 25, 2013 | SVP Aqua 5500 18mp Underwater Digital...
Doesn't recognize SD Card (2 different Minox cameras). Tried 2 different 4GB cards, also tried formatting cards on computer (FAT32).
Minox DM 1 probably cannot use 'SDHC' cards, which have capacities of 4GB+ because it was introduced around 2005, when memory cards were designated 'SD' and had much lower capacity
The supplied card was only 128MB so you might start by trying one up to 1GB, or 2GB at most. Luckily SD cards have become relatively inexpensive!
Jan 16, 2011 | Minox DM 1 Digital Camera
Can not read sd cards. The blue light goes on after introducing the SD card in the slot (the small one on left side), but "My Computer" does not show the folder even after refreshing.
Is you're card a SD HC (High Capacity) Card (usually > 4GB)?
Some older readers dont read the HC cards, if so the solution may be to buy a usb reader that will read SDHC cards.
Oct 27, 2010 | Toshiba Satellite M30 Notebook
I just insert a 4G micro card and says card error. Everything else works fine for 3 years ( never put a sd card before ). Thank you in advance Miguel
Check your mini SD card and see if it has the SDHC (high capacity) logo on it. Originally SD cards, including the mini SD, had a 2GB limit by protocol. The DC10 was introduced when this was the most advanced protocol. Since then the SDHC protocol has been introduced, but the DC10 is not compatible with SDHC. You need to get a mini SD, 2GB maximum capacity.
Mar 16, 2010 | Canon DC10 DVD Camcorder
Hi. I own a Canon A530 digital camera. I need to buy anew memory card for it. I would like to know if I could use a 4GB SD card for it? Thanks in advance.
Unfortunately, no. If it's a 4GB card, it is an SDHC card, which uses a different protocol than the 'standard' SD card. The maximum capacity of the SD protocol is 2GB, which is what the A530 is compatible with. (The SDHC protocol came out after the A530 was introduced.)
Mar 12, 2009 | Canon Cameras
Introduced an SD card with pictures into the slot
Have you tried removing the SD Card? If so, it's unlikely this has anything to do with the SD Card, it's probably coincidence. Try doing a hard power-off on the console by holding down the power button until the orange light on it turns red. Give it a few seconds then press the button to turn the system back on and see if it works.
Jan 03, 2009 | Nintendo Wii Console
SVP Aqua 5500 18mp Underwater Digital Cameravideo W/dual Lcd Screens Waterproof Logo
904 people viewed this question
Top SVP Video Cameras Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SVP Video Camera Expert? Answer questions, earn points and help others
