I added a wire by removing the bottom screws, removing the cover, and soldering a wire to the ground or sheild that is located near the wire chase of the tone arm. Careful, the wires are very little and fragile. Obviously the power was off...and presto ...no more ground noise!
These units are ground inside the decks. If you pop all the screws and remove the bottom, you'll notice where the RCA wires are hard wired into the unit, there is a small ground that comes out and attaches to several places inside the deck. Make sure this isnt severed or has a loose screw somewhere along the way. That should fix your problem, or give you insight to what may help.
Testimonial: "thanks alot:)"
