Apple iPod nano Logo
Posted on Dec 08, 2009
My iPod will not sync to my itunes and it reads do not disconnect
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
308
Points
My ipod is an 8 gb model:A1236..my ipod do not sync because it says that sync is locked?the playlist on my ipod exist but there is no song saved?how wil i retrieved all my playlist song on my ipod and how will i unlocked the said sync?plzzz help me...
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Nov 27, 2007
SOURCE: iPod touch freezes
Hello! This problem is if you messed around with your iPod Touch a lot like hacking it. I hacked it before so I restored it so now it is very good! It is now version 1.1.2. Okay, if you want to fix this problem, hold the home button and the power button for 20-30 seconds until a yellow exclamation mark shows up to tell you to connect to iTunes, this worked for my friend's screwed up iPod Touch. Try this method okay? After you connected it to iTunes, check for updates right away and there you go!
Hope this works!
Nicholas
Anonymous
  • 11 Answers
  • Posted on Nov 29, 2007
SOURCE: IPod Video 30 GB won't sync to itunes
  1. Okay you will have to Uninstall iTunes.
  2. Go to START CONTROL PANEL and ADD OR REMOVE PRGRAMS uninstal itunes.
  3. Go to apple.com/iTunes.
Anonymous
  • 35 Answers
  • Posted on Jan 07, 2008
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
A
Anonymous
  • Posted on Jul 31, 2008
SOURCE: ipod nano 2gb
retards
Anonymous
  • 38 Answers
  • Posted on Aug 01, 2008
SOURCE: iPod touch won't sync music from iTunes
your songs are probably not in the right format
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
3helpful
Downloading software
www.apple.com/itunes/download
iTunes is free and is the best software available for use with iPods. Below I have included several intruction (guides) for you just in case you are a new user and need the information. If you have any difficulties past here please do let me know. I have a well of information on iTunes/iPods. :)
---------------------------------------------------------------------------------- Adding content on your computer to iTunes
iTunes lets you add digital audio and video files on your computer directly to your iTunes library. You can add audio files that are in AAC, MP3, WAV, AIFF, Apple Lossless, or Audible.com (.aa) format. If you have unprotected WMA content, iTunes for Windows can convert these files to one of these formats. Video content in QuickTime or MPEG-4 format can also be added to iTunes. To learn how to add these files to iTunes follow the steps below.
Open iTunes From the File menu, choose one of the following choices: Mac Add to Library Windows Add File to Library Add Folder to Library Navigate to and select the file or folder that you want to add If iTunes is set to "Copy files to the iTunes Music folder when adding to library", iTunes will copy all content that is added to the iTunes library to the iTunes Music folder. Then adjust this setting or change the location of this folder, go to the Advanced tab in iTunes preferences.
Article: HT1333
iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
Products Affected iTunes, iPod nano (3rd generation), iPod classic, iPod (5th generation)
Syncing videos automatically Connect your iPod to your computer and open iTunes. Select your iPod in the DEVICES section of the iTunes Source list.
In the main iTunes browser window, select the Music tab. Select the checkbox labeled "Sync music" and verify that the "Include music videos" checkbox is also selected. You have the option to sync all songs and playlists or selected playlists.
Movies can be automatically synced to iPod. Select the Movies tab and select the option to sync all movies, selected movies, or a certain number recent unwatched movies.
TV Shows can be automatically synced to iPod. Select the TV Shows tab and select the option to sync all TV shows or selected ones. You can also determine which episodes are synced based on if they are recent or unwatched.
Video Podcasts can be automatically synced to iPod. Select the Podcasts tab select the option to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new or unplayed.
Click Apply and iTunes will begin syncing the content you've selected to your iPod. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
The iTunes LCD will display the sync progress and notify you when the iPod sync is complete.
To disconnect your iPod, select it in the Source list and click the eject icon.
Syncing videos manually If your prefer not to automatically sync video content to your iPod, you can setup manual syncing.
In the main iTunes browser window, select the Summary tab. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.
Click Apply. To manually add music videos, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a video or song.
When you are ready disconnect your iPod, select it in the Source list and click the eject icon.
1helpful
3answers
I just got a ipod shuffle and i want to add songs to it but dont know how to can you help me Please
I have an I-Pod Shuffle and I do not know how to use it. It did not come with a manual. Please help me.
My ipod nano (4gb) wont sync videos onto my ipod.
The videos need to be in itunes. If they are already i have some information that will hopefully be of use to you.
Last Modified: May 07, 2008 Article: HT1333 Old Article: 304680 Summary iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
CHEERS :)
How to put a song
If you do not already have iTunes downloaded you will need to do so before you will be able to add any content to your iPod. To download iTunes (IT"S FREE) go to: http://www.apple.com/downloads/ It is designed to walk you through the install. However if you have any issue's with that part of the proccess let me know for sure.
2answers
I have a apple ipod classic it won't download music from itunes
I cannot delete music off ipod nano 8gb help me please
Dont know how to recodd on my ipod nano 8GB
If you do not already have iTunes you will need to go to www.apple.com/downloads
and download it there.
2answers
Ipod nano not show (not play) songs
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
