Start light flashing and will not go out even after pressing button for more than 5 seconds on any program, with the only response being the pump runs for a short period
How many times does it flash there is a pause look for it, there is a tech sheet glued to the lower cover or to the bottom of the tub behind the lower pannel that has the codes discriptions and tests turn off power to it befor removing pannel
To program a new wall console for your Digidoor 3 to the receiver, follow these steps:
Connect the receiver to a power source and turn it on.
Press and hold the "Learn" button on the receiver for 5 seconds. The LED light on the receiver should start flashing.
Press and hold the "Learn" button on the new wall console for 5 seconds. The LED light on the wall console should start flashing.
Release the "Learn" buttons on both the receiver and the wall console.
Press and hold the "Open" button on the wall console for 5 seconds. The LED light on the wall console should stop flashing and the LED light on the receiver should start flashing.
Release the "Open" button on the wall console. The LED light on the receiver should stop flashing, indicating that the wall console has been successfully programmed to the receiver.
If the above steps do not work, you may need to reset the receiver and try the programming process again. To reset the receiver, unplug it from the power source and wait for 30 seconds before plugging it back in and repeating the programming process. If you are still having trouble, you may want to contact the manufacturer for further assistance.
1. Enter 5-digit permanent entry code into the keyless entry keypad. 2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock confirming you are in programming mode. 3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate succesful programming. 4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again to indicate succesfull programming. (If the keypad light goes out before all remotes are programmed the entire process must be repeated). 5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Here are the instructions from the factory service manual: 1. Enter 5-digit permanent entry code into the keyless entry keypad. 2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock confirming you are in programming mode. 3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate succesful programming. 4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again to indicate succesfull programming. (If the keypad light goes out before all remotes are programmed the entire process must be repeated). 5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
. Enter 5-digit permanent entry code into the keyless entry driver door keypad.
start light on and no other action could mean that the door catch has gone faulty, test accordingly and replace if needed, no wash cycle will work if this item is faulty, the waste outlet pump may be the only part that will work on some models, this is a safety feature
hope i have helped if so please rate me, work safe unplug when testing
