I bought my camera (Kodak M863) about a year ago. When it is fully charged, the battery only last 2 days (without me using the camera). I am still using the battery that came with the camera and it is the correct battery. I am also using the charger that came with the camera. Is it possible that the battery is damaged or is it the camera? Everytime I recharge the camera I have to reset the date and time. I have only taken about 1000 photo's with the camera. Is there someway that I can test the battery to find out if there is something wrong with it? What can be wrong??? Thanks
There is only one battery that is compatible with the camera. 1. You can also try to charge this camera using the computer. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair/Trade up or replace the cable please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
