Garden Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Missing nut to drive spindles. what size is it.
Missing nut to drive spindle to my troy built pony riding mower. what size is it?
Anonymous
Level 2:
  • Expert 78 Answers
  • Posted on Dec 01, 2009
Anonymous
Expert
Level 2:
Answers
78
Questions
0
Helped
56047
Points
181
Most of the spindle nuts Depending on the yr. are 5/8x18
HOPE that helps
My troy built briggs and stratton 22hp riding lawn mower when I engage it makes a clunk sound but the pulleys and blades wont turn
sounds like you have something stuck on the blades. if not check to see if you can turn the blades by hand all the way around. its possible the spindle bearings locked up. (with the engine off)
Jun 14, 2016 • Troy Garden
Two blade mower deck, bearing bad on right can I run with only 1 blade
if you do, you would have to figure out the new belt length and routing. It would be easier to just change the spindle. You could probably just replace the bearing but my guess would be the whole assembly would be about the same price on amazon. If you do change the whole assembly, make sure and keep your old spindle just in case you hit something and the caseing breaks.
I have Troy bilt Bronco 42" cut. The deck spindle fell and blades were on ground. Bearings still look good! What do I do?
The spindle bolts probably came loose and fell off. Look at the other spindle. Take one of the bolts (and nut) to the hardware store and get a matching set for the ones that were lost. Bolt the spindle back on - you should be good to go...
May 08, 2014 • Garden
Troy bilt 17.5 hp Pony Riding Mower,only works in fourth Gear
The bearings may be bad and freezing up, this will cause the belt to smoke and tear up as well as make the pulley wobble . Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release on front and side of deck. While the blades are disengaged turn all the blade hubs (shaft spindles) and pulleys to see if the turn fairly easy. Check for play or wobble in the pulleys and blade hubs (shaft spindles), bearings and blade shaft attach to these pulleys. Also check the idler pulley(also called the tensioner pulley for wear and check to see that they are in alignment with each other). It may be a bad transmission shifter plate bearing. Check out this link for diagrams of your unit. Hope this helps, plese post solved on fixya.com.So I get credit more info.for a solved problem if it does. If not, check back and give me
Troy Bilt Parts
Apr 22, 2014 • Troy Garden
The left spindle is loose, part is missing from housing??
both side are the same just look on the other side of the deck
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
4helpful
How to replace lower deck spindle bearing on my snapper riding mower
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Jul 09, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
