Tomtom GO 910 GPS Receiver Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Alarm sound went off while holding tomtom in hand, could not get it to stop so turned off by pressing top button. Now tomtom will turn on but keeps saying waiting for valid signal . Everything else is working(point of interest, etc....)
Anonymous
Level 2:
Champion:
  • Expert 243 Answers
  • Posted on Feb 12, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
243
Questions
0
Helped
84604
Points
382
Try to connect and update, it needs latest info about satelites.
3answers
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
How do I switch off the alarm on my CR1003 (model Number) Blaupunct bedside radio?
Setting the Alarm
1. Press and hold the 'Alarm/Sleep/Snooze' button to enter alarm mode.
2. 'Alarm Status' will be displayed and 'ON' or 'OFF' will flash on the second line of the display. Use the right hand rotary control to change the display to 'ON' or 'OFF' as required and press the right hand rotary control to confirm.
Stop the Alarm
When the alarm sounds press the 'Standby' button on the top of the radio. Alternatively, you can press 'Alarm/Sleep/Snooze' on the top of the radio.
Turn off the Alarm
Follow steps 1 and 2 in 'Setting the Alarm' and select 'OFF' in step 2.
Snooze function
When the alarm sounds, you can press the 'Alarm/Sleep/Snooze' button on the top of the radio. 'z' will be displayed in the bottom right of the display and the alarm will sound again in approximately 5 minutes.
15helpful
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
2helpful
Help needd to find out how ro set Alarm on my Bulova Millennia 98A48. A users guide would be appreciated. I have lost mine.
Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
I have a spare set of instructions if required.
15helpful
How do I turn the alarm off on a Athletic Works, AW60442W
I have the AW21312W, which has 4 buttons:
  1. Light (Top left)
  2. Mode (Bottom Left)
  3. Start/Stop (Top Right)
  4. Lap/Reset (Bottom right)
To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
Apr 02, 2010 • Watches
55helpful
2answers
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 • Swi Watches
How can u set the alorm??
To set the alarm, press the lower left button until "AL" appears.
Press and hold the center right button until the time digits flash.
Use top or bottom right buttons to set the time.
Press the center right when you have done setting the time.
Press the center left button to start or cancel the alarm.
The alarm will sound for 30 seconds; Press any button to stop.
Te alarm will repeat daily until it is turned off.
5helpful
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
90helpful
3answers
Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
26helpful
6answers
Aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Feb 11, 2008 • Watches
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
