My Iphone does not ring anymore. I cannot determine when a call comes in
Your iPhone not ringing might be caused by many reasons:
1. First, you can check to see whether your iPhone is set to the silent mode. If so, you will not be able to hear your iPhone ringing.
2. Check if your iPhone has turned on the "Do Not Disturb" button. Sometimes you may accidentally switch on Do Not Disturb option, which silences notifications, alerts, and calls. Your iPhone will not ring, but it still allows the phone calls to come in and as you won't hear the sound, you will see missed calls. In some cases, the user accidentally turns this feature on without even realizing.
3. You'd better investigate on your ringtone to ensure that your ringtone file is not corrupted or the ringtone itself is not silence.
4. Perhaps something wrong with your iPhone audio components. For instance, your iPhone speakers can not work normally.
5. When your iPhone is stuck in the headphone mode, you will fail to receive the ringing as well.
6. If you have turned the feature of "block unknown callers", you will not be able to hear the phone ringing of strangers that are not in your contact list.
7. It is probable that your iPhone software is too old, which calls for updating to hear ringtones normally.
To fix this issue, I found a tutorial for help: https://www.leawo.org/entips/fix-iphone-not-ringing-problem.html?fixya=1409
It happened to my palm treo....and my frends iphone too..just go to settings >sound notifications> and refresh your ringtones and it will work..dats hw i fixd my 1 and my frends'.
