Hi I have a Epson TM-T90. It works perfectly fine on my windows XP system: -Drivers installed
-Connected via the parallel cord
-Works great in this system
I have now upgraded to a windows vista system:
-Drivers installed
-Connected to the computer via the PARALLEL OUTPUT FROM PRINTER BUT USING A USB ADAPTER SO IT CONNECTS TO THE PC VIA A USB.
-In the printers folder (via control panel) it says printer is 'Not Connected' it won't even send a test page and doesnt connect.
Please help as i am in desperate need of receipt printer functionality!!!!
Thanks
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Did you install the drivers for the USB to Parallel adapter properly? Has a virtual parallel port been created, and is seen in the Device Manager as working?
And in the printer properties is it set up to use that virtual parallel port?
Go to Device Manager and look for entries that relate to your cable. Normally you would have one entry in USB devices, and an entry under "Ports", showing a parrallel port that does not exist if you unplug the cable from computer.
If it's there, then all you have to do is to go to your printer properties, Ports tab, and set the port to which the printer is connected to the one you've seen in Device Manager.
yes it did but i am running vista and it automaitcally installs the driver for the cable. how do i enter the settings myself?
The cable is installed onto my PC - thanks
Hi there - i am pretty sure the driver for the usb to parallel adapter is installed correctly. how can i check? a virtual parallel hasn't been created as i dont know how to do so. I cannot see it in device manager. the printer isnt set to virtual parallel port, how do i do this?
Usually these cables come with an install CD. Did you run the setup from the CD?
