I purchased an aftermarket external flash (Bower 724) for my DiMage A200. I am not a pro with cameras - and when I use the external flash in auto mode the camera is not compensating correctly, the pictures are all overexposed. Any suggestions on what settings to use?
Thanks!
Bill
SOURCE: Is it possible to control DiMAGE A200 from PC? (when DiMAGE A200 is connected to PC.)
No, the camera cannot be controlled from the computer.
SOURCE: My Dimage Z6 does not allow me to check the pictures taken.
i have the same problem. Did you get any answers? Thanks
SOURCE: overexposed pictures and white horizontal lines
I also having this problem white horizontal lines ...any solution?
If repair how much around?Please help!
SOURCE: Card for above camera
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I used the procedure set out by dwafellman and it worked for
me too! His translations from the French are, in English: Control Panel (configuration panel)>Administrative
Tools (administrator utility)>Computer Management (computer utility )> Disk
Management (disk utility) in Storage (stockage). I. e.,
Control Panel>Administrative Tools>Computer Management>Storage>Disk
Management.
Mille merci, dwafellman.
Vouz m’avez sauvé un voyage á Office Depot pour retourner mon mémoire
Flash.
imallan
SOURCE: minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
