20 Most Recent
Bower SFD35C for Canon TTL Flash Questions & Answers
My pictures are too dark
This cheap flash work normally if ISO is set to 400.
But put it aside and I bought Nissin 622di and it works great in all modes
Missing a User Manual
you can always try the site of the manufacturer or search for it on the web. it will usually come up as a PDF file so its handy if you have adobe installed.
Need manual
Why need a manual? the lens only can be used in complete manual mode. Once connected to your camera, the f /8 makes it impossible for your camera to focus automatically. Even if there was a focus motor it would not work. And it has only one focal length 500 mm, so there is also nothing to change. Then most cameras won't be able to set the aperture, so you have to set that yourself to. Best way to use this lens is to put your camera in M (manually) and dial in all settings yourself, till you have a good shot.
Battery incompatable
Just because someone claims a battery is compatible does not make it so. Nikon knows the specs of their batteries. Third-parties have to reverse-engineer to work out the specs, and they don't always get everything right.Stay with Nikon batteries, unless you want to jeopardize your camera just to save a few dollars.
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps:
Connect to Your PC:
Connect the standard USB cable (supplied) to a free USB socket on your PC.
The end of the USB cable should be connected to the socket on the back of the USB digidock.
Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation.
Install DigiConnect Windows® Software:
Insert your Digivue into the docking station.
If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue.
Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear.
If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe.
If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next."
Accept the terms in the License Agreement and proceed with the installation.
Choose the folder for software installation (default is the standard location for Windows® programs).
Click "Install" to begin the installation.
Leave the box labeled "Launch DigiConnect" ticked and click "Finish."
Wait for the Red LED:
Wait until a RED LED appears in the activity window of the Digivue.
You may now proceed with the next steps.
If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM •
Cameras
Answered
on Apr 01, 2024
