It may need a tuneup or ignition module replaced. Check the air filter, spark plug.
Good Day.
No bad gas, new or old in can or tank can always cause big problems. ALWAYS put STABIL in gas can & tanks of all gasoline equipment year around. Before 1st winter cold snap, if you have, put gas stabilizer in all gas containers/tanks! Keep spark plug cleaned. After removing spark plug on a no start it should be wet from getting gas if not check fuel lines. Helps to remove plug try to start several times, blows junk out of cylinder! Clean plug, check gap reinstall. Preventative maintenance cheapest routine on any engine. Lawn equip: Start of season change oil, filter, blow out cylinder, clean plug, clean grass area under deck, sharpen blade. I only run 93 octane in my lawn equip, no problems 8 years, with preventative maintenace! MikeC
Testimonial: "thanks for the advice"
put in new spark plug, changed oil, cleaned air filter, In the beginning it seemed to not start and run and i filled the tank with gas and it started and ran easier. Maybe it was the time delay.I was wondering if the weight of the gas would be forced through the system somehow?
Have u cleaned the spark plug, changed the oil?
