SOURCE: Disc Finalize stuck at 99%
Thank you for the help. I decided to return the unit - totally unreliable. Walmart wasn't stocking this product 2 days after I bought it - I think they had so many complaints they probably returned them all to the wholesaler.
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
SOURCE: Recorder fails during 92% finalizing.
The free CDBurnerXP Pro is supposedly able to close unclosed disks, but I have never figured out how to do it. Maybe you'll be luckier than me or the newer version is more user friendly.
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
