20 Most Recent
Lite On Cucusoft MPEG/AVI t Questions & Answers
AVI file is not running
With .avi files the issue is usually which video codec has been used to encode it - all players will have certain codecs installed, and if the second player you describe does not have the approprtiate codec then it will struggle to play the file - occasionally the audio codecs can have the same effect, also on video. In your video conversion program you should be able to choose from a list of codecs to use to encode the .avi file, check which one you used and then check it is installed on the computer that is experiencing the problem.
Windows media player, if it is fully updated should be able to cope with the majority of codecs, the best player for .avi files at the moment is DivX player, available free for download at;
http://www.divx.com
divx player also may need to be fully updated after you install it, this is an easy procedure, just click "Check for new versions" in the "help" menu to make sure you have the latest divx codecs installed
Hopefully this will allow you to play the files on both machines.
If you still have trouble, then type the name of the codec used by your converter program into a search engine, and you should find a location to download it from with installation instructions.
Hope this helps, ask again if you still have trouble :)
Install data extractor filter error
Uninstall all codecs including Divx. Then install the K-Lite Codec Pack 4.3.4 ****http://www.codecguide.com/*** which includes all the common codecs.
Exception in encodeDlg
I got the same encode error message after I installed
Cucusoft iPod Video Converter + DVD to iPod Converter
Suit along with the previous version.... version 8.8.8.8 did not work at all, and when I tried to use version v8.2.8.2 I got the encode error. I uninstalled both and reinstalled v8.2.8.2 and it worked just fine... the error went away and I could open the DVD and record it.
How to download movies to mp4
Hey! You can use some conversion tools which can convert movies to common video file including MP4 you have mentioned. I recommend you use this
Wondershare DVD Converter Ultimate which helps me convert both DVDs and videos into almost all kinds of video formats. I think you could give it a shot.
Hope that helps.
Gprs activation
hello you call your services provider for gprs setting and than your problem wsa gone
TLX-04243B Dead set Red blink lite on right front corner
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
1/17/2017 7:18:32 AM •
Lite On...
Answered
on Jan 17, 2017
-DVD Door will not open :(
FIrst switch Off the power supply.There is a hole just beneath the DVD tray. take a thin wire or unfold a office paper clip.Push the wire gently and the DVD will come out. There can be a mechanical failure, due to which it happened. switch On power supply, take our DVD try two -three times, if it works normally then i think ou problem is solved
12/25/2013 7:39:08 PM •
Lite On...
Answered
on Dec 25, 2013
