JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above.
To lock the control panel and both oven doors:
Press and release Cancel.
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Please see this link for more information as how to disengage the lock on your Jenn Air Oven---
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
