20 Most Recent
Jenn-Air JGS8750 Gas Kitchen Range Questions & Answers
Hi there...
Error F1-7 means --
Replace touch pad or clock assembly (also called the ERC).
Good Luck!!
Jenn-Air JGS8750...
Answered
on May 30, 2018
F9 is for the door lock relay fault. Does the lock work OK? Is anything else acting funny on the unit?
Jenn-Air JGS8750...
Answered
on Aug 31, 2017
Most of the time the solder on the control board brake because of the heat from the oven. Just remove the board and redo all bad solder. Sp?ciale the connector one.
Sorry for my english
Les soudure sur le board de control brise par la chaleur degager par le four. Il suffit de refaire celle-ci pour regler plusieures probleme en particulier celle des connecteurs.
Jenn-Air JGS8750...
Answered
on Apr 12, 2016
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jenn-Air JGS8750...
Answered
on Nov 06, 2014
good day,
hope this link below will solve your problem.
kitchen appliances
Jenn-Air JGS8750...
Answered
on May 11, 2014
Hi.
Use a multimeter to test the solder joints and the connector between control pad and electronic control module. Check that the solder joints and cable connector has continuity (impedance is not infinity between the two points of connector or between soldering and pin on board). If the connector on main control module is OK replace the control pad.
Here all parts and diagrams for this model.Regards.
Ginko
Jenn-Air JGS8750...
Answered
on Aug 10, 2011
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Jenn-Air JGS8750...
Answered
on Feb 23, 2011
HI. This F1 code, on this particular unit, will be a board level fault alert that will concern the actual touch pad or membrane switch. It may also be a strong indication of a watchdog error. Both indicators will result in the replacement of the main board or touch pad(membrane switch)
If this is a double oven build or newer style range/stove, This will be an indication of a failed power element relay(mechanical failure). Check the entire wiring harness assembly for shorts, in this case, If no shorts are found, replace the power relay board, asap.
NOTE_ For the double oven designs, you must replace the second PCB that is mounted within the structure and not the main.
Jenn-Air JGS8750...
Answered
on Jan 23, 2011
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jenn-Air JGS8750...
Answered
on Jan 14, 2011
