NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE
SET: press and hold BOTH the menu and input buttons at the same time
for at least 5 seconds and then release both.
This is the self check
this model has---power light should blink a two digit code---for
example--two blinks, a pause and two blinks and the set will repeat the
error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let
me know if you get an error code and I will tell you what the problem
is---hope you find 2,2 that is the most common and the most easy to
repair.
SD TECH
2,2 means most likely one of the two fuses that protect the convergence chip is blown---this model uses a single STK-393-110 CHIP--you need to replace it and the fuse or fuses blown and adjust the set.
Can you do this if I get step by step start to finish instructions to you?
I cannot post MY email address here but you...........
let me know if you want the instructions and how to send them to you.
SD TECH.
I just took care of this--let me know if you have questions
SD TECH
SD TECH,
The error message i recieved was 2 blink and then 2 blinks. What now?
Thanks
SD TECH,
You can email me at [email protected]
Thanks,
Dakota
