problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Im pretty sure when it gets to the point where it doesn't recognize its own screen is when its time to get a new ds. But if you really want to find out if it can be fixed (and don't mind paying more then its worth) you could to it to electronic shop or best buy to have them look at it.
If the green light is turning on and the screens are staying blank it is a problem with he L2 fuse on the motherboard (located just below the power button).
This can be replaced if you are handy with a soldering iron. If not drop it to a local repair shop it can be fixed for about €20.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
For GBA games the green light is meant to stay on. The orange light will stay on as long as its recharging. It will turn off when its fully recharged or when you unplug it
This is a problem with the cpu on the systemboard. I've seen this problem many times if the DS Lite is felt to the ground. The contacts of the cpu are very fragile. The DS Lite turns on, green led available, even charche is working bot nothing else. Repair of this problem is almost impossible. The only thing you can do is send it to Nintendo.
You can test if it is the cpu by removing the bottom of the DS Lite and put the battery on te contacts. Press firmly on slot 1 (the aluminium cover) and turn the DS Lite on. If you got a picture on the screens then you know it for sure. The cpu is located under slot 1 and by pressing on de top of the slot you are pressing possible loose contacts back on de systemboard.
If it is not working then the cpu is to musch damaged.
When you boot the Nintendo DS you can change the illumination settings in the main menu. One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
