There, there is counter, which it is necessary to throw each 12 thous.. (making at preventive maintenance of the printer). For installation new cartridge it is necessary simultaneously to press shift Ctrl F1.
In connection with extension market copiers Panasonic and with all becoming more frequent questions in Conferences has solved be divided accumulated by information.
The Whole hereinafter presented information pertains to device of the serieses DP
Now about that, what fall into service mode; for entering we press consecutively: key "FUNCTION", key "ORIGINAL SIZE", key "3".
For emergency input in switched off condition hold the keys "FUNCTION" and "STOP" for DP-1515, for the other device - a keys "FUNCTION and "CLEAR", and snap the tumbler of the feeding.
Now we in service mode, possible installthe developer; for what we call at in mode F8-09 and wait the completions of the process for 3 minutes. If this first start or was changed the drum, that executes the procedure F8-14. For leaving from service mode жмем on keys "FUNCTION" simultaneously and "Clear".
Most often used functions of the service mode:
F7 02 General counters mines
F7 03 Counters mines before following preventive maintenance Unset "wrench" is produced by record in cell F7-03 importances 0
F7 06 Counters mines on installed drum
F7 10 Counters mines on the same developer
SOURCE: Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Testimonial: "Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you."
