You must be Canadian?
F11 means that the controller thinks there is a stuck key on the keypad, which may or may not be the cause.
You might try pushing each button several times, then the clear button to see if you can unstick it.
Sometimes this is caused by a failure in the oven controller itself (but more often the keypad).
We repair oven controllers if it comes down to that.
Happy Canadian Thanksgiving!
Bruce
www.fixyourboard.com
Testimonial: "Thanks - guess I'll stay near my oven until I get it fixed. Perhaps the cleaning ladies went at it too hard yesterday!"
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
F11= Temp Sensor Failure
The part that has to be replaced is the sensor located in the oven.
Its the part that looks like a metal small rod sticking out from the oven back wall.
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
