It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Testimonial: "Thanks! Thought that it might be something like that.... just strange to hear water noises and not see any water. :)"
It may be nothing to be concerned about. The water that is produced when the refrigerator defrosts runs through tubing into a drain pan underneath the refrigerator. This water is evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan. Look under the refrigerator on the freezer side, and you will likely see this pan.
Normal...
The freezer is defrosting.
When the compressor starts up again, pull-out the drip pan under the fridge and empty it. It will be very cold!
SOURCE: Ice forming on bottom of freezer section
The freezer should have a drain hole for the defrost water to flow through. This will drain into a pan outside of the freezer cabinet. If this drain tube becomes blocked it will not allow the water to drain out and it will accumulate in the bottom of the freezer section. You will have to verify that the drain is clear through to the drain pan. this can be done carefully with a piece of stiff wire. There should also be some sort of a water trap on the drain tube to prevent air from entering the freezer compartment through the drain tube.
SOURCE: Samsung RS20CCMS side by side fridge/freezer
Just to expand on the excellent advice from woodchuckie - I had the same problem and these are the steps I took to resolve.
1) Remove the back panel. There are about 7 screws to undo.
2) The drain tube is towards the middle about 3/4 inch in diameter.
3) Remove the tube. I found a little black rubber 'flute' which I have now removed as I think this was causing some back pressure. Make sure the tube is clean and free from dusty gunk. Mine was anyway hence the removal of the flute.
4) Remove everything from the lower 2/3s of the freezer compartment. Remove the screws (some are covered by white caps) there are about six. You must remove all the screws up to the place where the top panel starts.
5) The back panel may be frozen in place. From a standing position reach down and grab the protruding plastic - pull up and out. The panel should loosen. Turn it sideways to remove it.
6) You should now see the freezer matrix and the frost free heater pipes at the bottom. If your like me you will see a block of ice at the bottom!!
7) I took a hair dryer (carfull of the water/electricity hazzard) and melted the ice (also be careful about melting the plastic of the freezer!! doh).
8) With a sponge remove the loose water.
9) The drain is in the middle and is difficult to get to.
10) I took a screw driver to the hole and jabbed at it.
11) Boil a kettle and fill the shallow tray around the drain. If your lucky the water will work through quickly and you'll hear it falling into the evaporation tray. If not then keep sponging the water out and replacing with boiling water (and have a few more jabs with a screwdriver!). Keep working it untill you have success.
12) Ensure that the interior of the freezer is dry ( I blew some air from the hair dryer through the drain and got someone on the drain at the back to confirm they could feel it coming through.
13) Replace all the plastics, back panel and screws. Put everything back in the freezer, plug it back in and set it to power freeze.
The whole thing took about 45mins - 1 hour.
Hope this helps.
SOURCE: Water leaking from bottom
There is usually a water cut off , behind the refrig , mounted on the wall , or , a cut off under the sink , connected to the cold water line ( with a small cut off valve ) .
The hissing noise , is usually associated with a hole or cracked water line . You can also try removing the ware filter , to see if the noise stops .
Would need more info , to have an idea where the water line is defective .
Testimonial: "Thanks so much! Your feedback got me headed int eh right direction. With a little help from Home Depot as well, and we were able to fix the problem!"
