20 Most Recent Whirlpool WRS325FDAM 25.4 cu. ft. Side by Side Refrigerator with Adjustable Gallon Door Bins, Slide-out SpillGuard Shelves, LED Interior Lighting, Energy Star Qualified and External Filtered Water and Ice Dispenser: Stainless Steel Questions & Answers
3answers
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
12/28/2020 11:44:11 PM • Whirlpool... • Answered on Dec 28, 2020
Whirlpool wrv986fdem01 no lights
Check the control panel or display on the refrigerator for any error codes or indicators that might suggest a malfunction. Reset the control panel by unplugging the refrigerator for a few minutes and then plugging it back in.
4/3/2024 9:01:44 PM • Whirlpool... • Answered on Apr 03, 2024
Whirlpool refrigerator model WRB322DMBM0 1 with ice maker only. How do I find and change the ice maker filter
The Whirlpool WRB322DMBM01 refrigerator model typically does not have a dedicated water filter for the ice maker. Instead, it relies on an external water filtration system or an in-line water filter that may be installed in the water supply line connected to the refrigerator. Here's how you can check for and change the water filter for your ice maker: 1. **Locate the Water Supply Line**: Trace the water supply line that connects to the back of your refrigerator. The water supply line is usually a flexible plastic or metal tube that runs from the water source (such as a water pipe or faucet) to the refrigerator. 2. **Check for an In-Line Water Filter**: Look along the length of the water supply line for any inline water filters. These filters may be attached to the water line using compression fittings or push-to-connect fittings. They are typically cylindrical or rectangular in shape. 3. **Inspect the Filter**: If you find an in-line water filter, inspect it to determine its type and condition. Some filters have a label indicating the brand and model number, while others may have a date or indicator showing when it was last replaced. 4. **Replace the Filter (if Necessary)**: If the water filter is due for replacement or is visibly dirty or clogged, follow the manufacturer's instructions for replacing it. This typically involves turning off the water supply, disconnecting the filter from the water line, and installing a new filter in its place. 5. **Flush the System**: After installing the new filter, flush the water system to remove any air or debris. Run water through the dispenser or activate the ice maker to purge the system of any trapped air or loose particles. 6. **Monitor Performance**: Monitor the performance of your ice maker and water dispenser to ensure that the new filter is functioning correctly. It may take a few cycles for the water system to fully adjust to the new filter. If you cannot find an in-line water filter connected to your refrigerator's water supply line, it's possible that your refrigerator does not have a built-in water filtration system for the ice maker. In this case, you may need to consider installing an external water filtration system to improve the quality of your ice and water.
4/3/2024 12:33:05 AM • Whirlpool... • Answered on Apr 03, 2024
How to replace freezer light
Delete To replace the LED light in your Whirlpool WRSSDHW08 freezer, follow these steps:
  1. Unplug the refrigerator to ensure safety.
  2. Remove all the items from the freezer to give yourself more room to work.
  3. Locate the light cover inside the freezer. The LED light should be underneath this cover.
  4. Carefully pry the light cover off using a flat-head screwdriver or your fingers. Be gentle to avoid damaging the cover.
  5. Once the light cover is removed, you should see the LED light module. It may be held in place by clips or plugs.
  6. Disconnect the power supply to the LED light. This may involve twisting or pulling the plug from its socket.
  7. Remove the old LED light module from the freezer.
  8. Purchase a replacement LED light module from the Whirlpool website or an appliance parts store. Make sure to get the correct part number for your specific refrigerator model.
  9. Install the new LED light module by connecting it to the power supply and placing it back into its slot in the freezer.
  10. Replace the light cover by snapping it back into place.
  11. Plug the refrigerator back in and test the new LED light.
If you have any trouble replacing the LED light or if you are unsure about any steps, consult the user manual for your Whirlpool refrigerator or contact a professional appliance repair technician for assistance.
3/29/2024 9:30:21 PM • Whirlpool... • Answered on Mar 29, 2024
Why is my whirlpool refrigerator ice maker not working on whirlpool model # WRF535SMBM00. It seems we have no water filter
https://www.appliancepartspros.com/repair-help/whirlpool-refrigerator-wrf535smbm00-repair/wrf535smbm00-ice-maker-not-making-ice.html Whirlpool Refrigerator WRF535SMBM00 Ice maker not making ice Causes of a bad icemaker cycling thermostat can include electrical malfunctions, temperature sensor issues, or wear and tear. Symptoms of a bad icemaker cycling thermostat may include: Inconsistent ice production. The icemaker not cycling properly.
HOW-TO: Whirlpool Refrigerator WRF535SMBM00 Ice maker ...
There is no water filter.
Where is the filter for water for ice maker located on
JustAnswer https://www.justanswer.com > Appliance Repair Jul 23, 2018 - This particular model does not have a filter built into it so that is why you can't find one. If you wanted to add a filter, you can get an in- ...
2/23/2024 6:13:04 AM • Whirlpool... • Answered on Feb 23, 2024
2answers
Whirlpool refrigerator running continuously won't shut off but is not freezing stuff in fridge and freezer is working fine
Sounds like the evaporator fan is not running. Pull the inside of the freezer back off to expose the motor and replace it.
2/21/2024 6:59:51 PM • Whirlpool... • Answered on Feb 21, 2024
Whirlpool freezer defrosting too often causing food to thaw.
If it has a defrost timer, some are adjustable. If not just replace it. https://www.google.com/search?q=Whirlpool+freezer+defrosting+too+often ..
1/7/2024 7:49:35 PM • Whirlpool... • Answered on Jan 07, 2024
Whirlpool ET1MTKXKQ20. Temperature control.
Question edited for clarity, spelling of maker, toss in a load of CAPS. Question moved from Cars and Trucks. Yes they do. https://www.google.com/search?q=whirlpool+et1mtkxkq20 ..
1/1/2024 3:13:20 AM • Whirlpool... • Answered on Jan 01, 2024
Ice maker issues... Maytag Whirlpool French Door Icemaker in upper left. Help?
Question edited for clarity Zeros (0) and ohs (o) aren't interchangeable in serial numbers :>D If icemakers are going wrong it is best just to replace the complete icemaker unit. They work in a very hostile environment or cold, wet, electricity and limescale and bio-slime. Some commercial icemakers I have witnessed in catering facilities would have you never taking ice in a bar or restaurant again! https://www.google.com/search?q=Whirlpool+MFI26665XEW3+parts ..
10/17/2023 6:22:18 PM • Whirlpool... • Answered on Oct 17, 2023
6answers
I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions? [email protected]
10/7/2023 6:12:17 AM • Whirlpool... • Answered on Oct 07, 2023
Whirlpool refrigerator is not getting cold but freezer is freezing. Can someone help, please?
As the freezer is working you can probably discount that the reason is low refrigerant gas. The other reasons would be that the fridge circulation fan has failed. or The channel that directs cold air from the freezer is blocked with ice at the rear of the freezer. It happened to my GE and was caused by a failed defrost timer that was icing up the evaporator coils at the back of the freezer. A service call lasts about an hour including melting the ice with a heat gun..
10/3/2023 2:45:18 AM • Whirlpool... • Answered on Oct 03, 2023
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine b
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
9/29/2023 7:42:49 PM • Whirlpool... • Answered on Sep 29, 2023
My Whirlpool six sense American fridge freezer Digital display showing faults
A clue to what the faults were may help you get an answer.
9/29/2023 7:35:42 PM • Whirlpool... • Answered on Sep 29, 2023
How can I remove the top drawer from the bottom freezer of a Whirlpool fridge as the bottom drawer will not fully close?
Remove the ice build up at the back of the drawer or something may have fallen over the top edge.. To remove the drawer, lift at the front and pull, or look on the side rail for catches. Please always include full 'make model (what it is)', then we can refer to the owner or service manual.
9/29/2023 7:30:41 PM • Whirlpool... • Answered on Sep 29, 2023
Whirlpool refrigerator compressor
I would seriously NOT recommend doing this! Trying to run a 110 volt appliance at 220 volts is too much power for the electrics inside the refrigerator (or any 110v appliance) to cope with. You will 'Fry' the electrics possibly even risking causing a fire. Do you have a model or serial number for this refrigerator? You might have to see if you can source one online and import it from the US. That could get expensive! A simple and obvious answer here if the part is so difficult to get, is to buy a whole new refrigerator. Compare the cost of both options as it may be cheaper to replace the whole appliance.
9/3/2023 11:47:37 AM • Whirlpool... • Answered on Sep 03, 2023
Whirlpool WRS325FDAM 25.4 cu. ft. Side by Side Refrigerator with Adjustable Gallon Door Bins, Slide-out SpillGuard Shelves, LED Interior Lighting, Energy Star Qualified and External Filtered Water and Ice Dispenser: Stainless Steel Logo
2 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
stop flashing strobing lights inside
  • Refrigerators
