I bought a Garmin Nuvi 1300 series in the US. I live in Brazil. There, I got it unblocked it and added Brazil's map. On the US it was working fine, but when I got to Brazil it didn't work at all. It worked for one time, but now it only searches for satellites it won't find.
What can/should I do to fix this problem?
You should have the need to Garmin Nuvi 1300 update with the latest version. After updating GPS Nuvi 1300 restart then you find the device is working fine.
Read here more step to update with the latest version software Vist our website Garmin Nuvi 1300 update
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
SOURCE: Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
SOURCE: Well my Garmin nuvi 1300 was working fine
it sound like someone has "unticked" maps go to settings then maps and map info and look for the screen that says city navigator, and tick box that should work unless someone has attached to pc and wiped maps
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
SOURCE: my garmin nuvi 1300 shuts
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
