I have had my BB Storm for one week. The green answer and cal button will not allow me to make calls nor answer them. This is every single call. Also, it has this little bity clock icon show up in the middle of my screen with every function I try to do. It slows everything down or does not work at all.
SOURCE: Email messages do not appear in inbox on Blackberry Storm
Dear Vbcarroll,
on your blackberry go in main menu- options- advance options- default services. if you have enterprise mail account setup with personal mail account, it can be the case that at the moment it is showing as desktop services but when you are in there click on main menu and change options to other mailbox which is in your case personal mail account.
that way in inbox you will receive both emails and you can see all together.
but as far as i know, I haven't setup personal account on my blackberry but i believe within main menu you get created another icon like mobile mailbox and where your personal mailbox emails are coming in. if option one doesn't work then please try to look for this new created icon within main menu.
update me if none of them are working or any other problem.
Thanks.
Regards,
AJoshi
SOURCE: when click bb button my options buttom doesn work
If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
Hope this helps!
SOURCE: Blackberry storm screen will not display any icons
Hi ,
you might have get confused and updated with a wrong firmware ?
as those available in 2 models 9500 and 9530 ?
Best Regards
SOURCE: random rebotoing - white screen with clock
The BB Storm is plauged with these problems unfortunately due to insufficient hardware & buggy software.
There is hope however - you can try update your software. You can find it here
SOURCE: mms messaging to bb storm
In short, no. MMS requires a BB Data subscription and there is no other way to get around it.
GENERAL PROBLEM
» Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
UNLOCK CODE
» Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
omitsana15
