Computers & Internet Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the processor on a dell optiplex gx 280 from the heatsink and repaste the processor seems to be like glued to the heatsink?
Anonymous
Level 3:
Genius:
  • Master 1,027 Answers
  • Posted on Sep 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1027
Questions
0
Helped
380678
Points
2770
The heatsink compound does act as a weak glue over time. To remove the heatsink, twist gently after removing the clamps, to release the junction. The CPU should stay in it's socket. Scrape off the old compound and add new and re-install the heatsink.
Dell gx 280
THAT QUESTION YOU SHOULD ASK A GAMER'S FORUM.
Dell Optiplex S280. Alert! Chipset heat sink not detected.
There is no S280 in the Optipex model line, just GX 280 and SX 280.
The problem you are describing is common to the GX 280 model.
Here is a link to the manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx280_user%27s%20guide_en-us.pdf
Select "Small Form-Factor Computer" and then select "About Your Computer". Scroll down to "System Board Components".
To the right of the processor is a smaller heat-sink attached to the motherboard via a wire similar to the size of a paper clip bent open. That wire is soldered to the motherboard which may have loosened it's connection and the circuit is open. This heat-sink on the chipset of the motherboard. The wire needs to be re-soldered to the motherboard.
I have DELL Optiplex GX 280 .. when i plug the computer on power .. that turn on automatically then have very loud fan noise , no blinking lights and the processor work good on another motherboard and ram...
Hi, Thanks for using fixya.
I have the same computer with the same problem. I changed the power supply that cured it for me, I hope it does the same for you.
Terry
Dell Optiplex GX 280 bios location to reset default to remove the existing password.
Hi, take the small round battery out of the mother board for about 5 minutes
and put it back in, and that removes the password,
2answers
Sound problems after reinstallation of windows
Did you install it to the factroy default installation or did you install windows anew?
You need to install the Dell sound drivers. They're found on the dell home page or on your media that came with the Optiplex.
Also, check the system control / administtration / hardware section to see if windows potted a problem with the hardware.
2answers
Checkpoint [ithr]
the problem description is
Ithr
Smm mode is initializing the thermal probes.
problably the system is running at high temperature because of improper fan speed, so try to clear the nvram if its not working flash the bios if still the issue persists, replace the heatsink assembly and the motherbord.
5helpful
2answers
4helpful
2answers
Windows vista does not accept vga and sound driver
download driver ''R145551.exe'' and install it for audio device to work. you can download this by typing the r145551.exe on google search for more details contact me [email protected]
Dell gx 280
check your motherboard manual for the compatibility of processors
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
