Graco Quattro Tour Travel System Logo
Posted on Sep 22, 2009
Adjusting seat in graco stroller
How do I adjust the seat in the graco stroller. I am having trouble moving it from the recline to sitting up position
Anonymous
Level 1:
  • Contributor 14 Answers
  • Posted on Sep 29, 2009
Anonymous
Contributor
Level 1:
Answers
14
Questions
0
Helped
9777
Points
39
Our was an older model, but we just pushed it up and it clicked into place.
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Feb 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
12200
Points
39
Jacquelyn, you need to specify the model of your graco stroller.
G-Luxe Stroller by UPPAbaby. The seat adjuster doesn't really work. I can recline seat or pull it up from the front, but the lever doesn't work to return it to upright position. Can I fix this myself?
Question edited for full 'make model (what it is)'.
Question moved from Spanish car company Seat pronounced See-At.
It sounds like a broken return spring. Contact them with a view to a warranty repair or purchasing the part.
G-Luxe Stroller - UPPAbaby
uppababy.ca https://uppababy.ca > Strollers
Whether running errands or catching the sights during naptime, your child can rest comfortably in our one-handed reclining seat with adjustable footrest.
Support and Parts
https://uppababy.ca/shop/spare-parts/for/g-luxe-2018-2022/
How do you prop up seat from reclining to sitting position
Hi
We would recommend you contact Graco for assistance
Contact Us Graco
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
Install graco snugride to a graco stroller
Fitting your Graco Snug Ride infant seat into a Graco stroller is usually easy to do -- the exact instructions just depend on which stroller you have. Typically, all you have to do is fold the stroller's canopy back, recline the seat (if it reclines), and snap the car seat in (backwards -- facing the rear of the stroller). You can hear it lock in place when it's in correctly. Your stroller's manual will have specific instructions, and if you don't have the manual you can find it online.
Which Graco stroller do you have?
5helpful
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Graco Cleo - travel system
Hiya, are you still wanting the manual. I can scan it for you if you want and email it. Email me on [email protected]. There is an adjustable strap behind the seat for raising and lowering the seat back. Its quite self explainatory if you look at it. I had the same problem
1helpful
How to change reclining position
Viewed from behind, there are two cords with pull tbs that are gathered together in the center of the seatback with a black plastic gather. These two cords are loosen or tightened to raise or lower the seat back recline position.
3answers
Adjusting the seat
I'm having the same dilemma. I just got this at a consignment sale. It seems in perfect condition. I think that the amount of sitting/reclining is only what you get by pulling the red tab. I don't think it is meant to sit all the way up. It loosens the same as you would loosen a belt strap. I wish it had a locking mechanism.
I can't figure out what the rubber "button hole" looking tab is on the left side near the front hinge of the overhead shade.
2helpful
3answers
Need to recline seat
On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
