20 Most Recent
Baby Trend Expedition LE Jogger Questions & Answers
Spray the hinges with WD 40 as the locking mechanism maybe be rusted and stuck. May need to be lubricatred to get the gears to work again.
Baby Trend...
Answered
on Aug 18, 2020
Infant safety seats can only guarantee protection for your baby if it is in new, original condition. Seats are vigorously tested according to National Institute of Science and Technology (NIST) standards and is the only way to be certain of their effectiveness during a crash. Unfortunately, to ensure your child's safety you will need to get a new seat.
Baby Trend...
Answered
on May 08, 2019
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Baby Trend...
Answered
on Aug 19, 2016
On mine, I push the seat forward to the position I want, then there is a string behind the seat at the top with a toggle on it that I pull until it's tight and push the toggle up as close as I can to the seat to secure it in place.
Baby Trend...
Answered
on Sep 06, 2013
Be ready, this is a little bit of a dirty job, have rags handy.. What you need to do is coax the tube back inside the tire, without damaging it. Use hands only, no screwdrivers or other tools.Sometimes letting all of the air out helps, some air back in helps...but you need to wind up with the tube fully inside the tire and NOT at all in the tire bead to rim area. This is where the add air helps...When you achieve the above steps, you need to ensure that the tire bead (the part that actually touches the wheel) is even and seated all the way around. INSIDE and OUT... Then add air and often check that the tire bead is still correctly located inside the wheel. (What happens is the bead goes deep into the rim on one side, and that allows the tire to go clear past the wheel on the other side...Just center everything..)Then blow the tire up to the correct pressure. I think you want to be a little on the high side, as the tires need to be able to roll with low resistance, and that takes pressure.I hope this helps. Check all of the other tires for issues and pressure and cruise on. Doc
Baby Trend...
Answered
on Aug 05, 2013
I bought this stroller at toys are us. And the front wheel warbles when we are not going straight. The inner part is not right. It isn't even a year old. What can be done.
Baby Trend...
Answered
on Jun 19, 2013
On the footrest is a plastic oval motif.
Flip the push chair over and pop the two lugs out and remove.
You will see a nut.
Use a 17mm ring spanner to tighten this up so the wheel doesn't swivel easily by hand (the weight of the push chair will still swivel it properly).
Bingo! No more wobbles.
Press the grey clip back over the nut.
I know this works because I did mine this afternoon!!
Baby Trend...
Answered
on Apr 14, 2013
i found them on ebay, just math the numbers listed on the bearings you have.they are the same bearing commonly used on skateboards.jay
Baby Trend...
Answered
on Sep 07, 2012
