Expert
- Posted on Jan 17, 2023
Re: I have a saluspa Miami when I plug it in I get...
If your Saluspa Miami hot tub is not turning on and you are getting no power to the control panel, even though your tester is showing power all the way to the panel, there may be a few different causes.
- Check the circuit breaker: Make sure the circuit breaker for the hot tub is not tripped. If it is, reset the breaker and see if that resolves the issue.
- Check the GFCI (Ground Fault Circuit Interrupter) : Make sure the GFCI for the hot tub is not tripped. If it is, reset the GFCI and see if that resolves the issue.
- Check the Control Panel: If you suspect the control panel is the problem, you may need to replace it or have it repaired by a professional.
- Check the wiring: Make sure all the wiring connections are tight and secure. Look for any damaged or frayed wires.
- Check the heater: If the heater is faulty, it can cause the hot tub to not turn on.
- If none of the above steps work, it is possible that the hot tub has a more serious problem that requires professional service.
It is important to refer to the user manual or contact the manufacturer for specific troubleshooting steps for your hot tub model. It is also important to make sure the hot tub is not plugged in before attempting any troubleshooting steps.
