v
valerie cornelius Posted on Nov 04, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coby Keychain won't come on?
I have not turned it on in long time. I've charged it up it, it says USB connected but wont start.
ADMIN Andrew
Level 3:
Top Expert:
  • Coby Master 66,975 Answers
  • Posted on Nov 04, 2022
ADMIN Andrew
Coby Master
Level 3:
Top Expert:
Answers
66975
Questions
Helped
5089124
Points
379905
2answers
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
1helpful
Product: Innovage Digital Photo Keychain Issue: Not holding a charge In a nutshell, the hardware works (I've already used the minicd to load the software, and have even put pictures onto the...
What probably happened is the battery slowly drained on the shelf and its shot. Basically the type of battery in these (and a lot of other devices) can not be left with a very low charge for long periods of time or it degrades them. What happened is the battery just degraded and now cant hold a charge.
21helpful
3answers
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
Hello! I'm trying to find how to upload my coby photo keychain DP 151. I have a new computer with Windows 7. Can you help me? Thank you
All you do is plugin the keychain to your computer, (make sure you push the cable all the way into the keychain), the softwre should auto popup on your computer screen.
If not, connect, then go to 'Computer under your start button, it will be labeled as a CD rom drive, double click it to access it.
Freezing glitch on coby m600-4g
I have a Coby Digital Photo Keychain and I plugged it in to the computer and then I unplugged it and the screen says "USB Connected" and nothing happens when I push or hold down any of the buttons. Please help!
No icon is coming up when the digital photo keychain is connected to the computer via the USB. the keychain is charged, the screen is displaying the generic photo already on it but, no icon and no transfer...
When the cam is connected to the computer no pics will show on the LCD. While charging through the USB the cam. will not be able to transferre pics at the same time.
The cam either charges or transferres.
Oct 02, 2009 • Cameras
12helpful
6answers
I have a coby dp-161 and cannot get the pictures to install.
We had the same problem and you won't believe how simple the actual fix was!!! When you plug the USB plug into the keychain device or whatever device you are using (in our case it was a keychain), make absolutely certain that the plug is pushed in all the way (it is tough to push in) until it actually clicks and all you see is the black part of the USB plug. Then try your software. It should work!!!
2answers
Cannot get keychain to turn on when dissconnected from computer
Sounds like your battery is dead.
1. Please note that when charging from your USB cable to the computer, full charging time will take up to 7 hours. If you are charging using your own DC car charger or AC wall adaptor,
charging time will be much less and will take up to 3 hours.
2. Indicator light will turn green when charging is complete.
Jan 06, 2008 • Baby Gear
17helpful
4answers
Digital photo keychain
go to their website... www.mscustomercare.com and they have the drivers and stuff there....The problem i have is that after ive charged it for 3 days it wont turn on! It works when its plugged into the USB but as soon as i unplug it....wont turn on!
13helpful
23answers
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 • Baby Gear
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
