Refrigerators Logo
A
Anonymous Posted on Jun 19, 2022
After you reset a Frigidaire model fghs2631pf, how long does it take for the refrigerator to start cooling and for the temperature to change.
ADMIN Andrew
Level 3:
Top Expert:
  • Frigidaire Master 66,980 Answers
  • Posted on Jun 19, 2022
ADMIN Andrew
Frigidaire Master
Level 3:
Top Expert:
Answers
66980
Questions
Helped
5090488
Points
379943
Starts cooling in 10 minutes and to the set temperature in 2 hours.
How do I change temperature from Celsius to Fahrenheit on Frigidaire Gallery Refrigerator, model EPTWFU01?
EPTWFU01 is the water filter part number. It isn't the model number of the refrigerator. Please check the model number. Often the model number is on the back of the refrigerator. Not all models support changing the temperature units. If your refrigerator has a button labeled C/F. Try pressing that to toggle back to Fahrenheit. On another model, FG4H2272UF, press and hold the + and - keypads on the refrigerator side of the control panel for 5+ seconds.
One Frigidaire Gallery refrigerator is the GLHS36EJSB.
The support page is https://support.frigidaire.com/Owner-Center/Product-Support/GLHS36EJSB . The current link to the manual for this model is https://na2.electroluxmedia.com/Original/Electrolux/Electrolux%20Assets/Document/Complete%20Owners%20Guide/English/241856000en.pdf . This model doesn't allow the units to be changed. The documentation for FG4H2272UF is available here: https://support.frigidaire.com/Owner-Center/Product-Support/FG4H2272UF . See the page 15 of the manual, https://na2.electroluxmedia.com/Original/Electrolux/Electrolux%20Assets/Document/Complete%20Owners%20Guide/English/A10883135en.pdf , for the information above.
I hope this helps. Please add a comment with your refrigerator's actual model number for specific directions for toggling between degrees C and degrees F.
My samsung frige, french doors keeo ringing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
The temp reads 65f. when I change it to 0-33 it goes back to 65f
Thank you for your post, janet!
I understand that your Frigidaire refrigerator is not displaying the correct temperature. Is it cooling? If it is cooling it could be an issue with your control panel or thermostat not registering the appropriate temperature within your refrigerator. I would suggest performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience a display problem or that refrigerator is not cooling I would recommend reaching out to a professional for proper diagnosis and repair. This will help you to avoid purchasing unnecessary parts. I hope this is helpful. -Matt
Model FFHT1826LK refrigerator not getting cold but freezer is?
Good Afternoon Friend,
I understand the freezer portion is cooling on your Frigidaire refrigerator, model# FFHT1826LK, but the refrigerator portion is not cooling. I suggest turning the temperature down in the refrigerator portion and give it 24 hours for the temperatures to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
What would cause my freezer to freeze, refrigerator not cool, fan in back runs, motor hot
Good Morning Carlene,
I understand the freezer is freezing, in your Frigidaire refrigerator, but the refrigerator portion is not cool. I also see that the fan in the back is running and the motor is hot. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, stop the alarm, and press the "Factory Default" button. This will reset your temperatures to 37F on the refrigerator side and 0F on the freezer side. Keep an eye on your refrigerator temperatures, to see if they go down. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Freezer and refrigerator are too warm
Good Morning Friend,
I understand that your Frigidaire refrigerator, model#FRS6R5EMB, is not cooling well. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire flsc238js1why wont it cool?
I understand that your Frigidaire refrigerator, model#FLSC238JS1, is not cooling well. I suggest cleaning underneath and behind the kick plate of your refrigerator, with a vacuum extension. I also suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
I have a frigidaire FGHC2342LF and the refrigerator is not cooling
Good Afternoon Rick,
I see that you are having trouble with your Frigidaire refrigerator, model# FGHC2342LF, not cooling in the refrigerator portion.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your refrigerator, give it an hour to 2 hours to see if the temperature restores to the suggested temperature of 37 degrees for the refrigerator and 0 degrees for the freezer. If the temperatures do not go down, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
2answers
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
