My AEG Favorit Dishwasher is leaking water from underneath the door. It is only 3-4 years old and seals look good. Seems to be leaking out between the fascia door and the dishwasher door at the bottom
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
I assume that this leak is from the flat tank on the side of the machiene. Any water leak to the bottom of the machiene puts the washer in ANTI FLOOD mode with the pump out motor activated. You can remove the flat tank by disconnecting the hoses to it and pulling it upwards. If you find a small leak just run it over with a hot soldering iron to melt closed the small leak. Also note that this tank has a small outlet pipe that deliberatly discharges water to the anti flood device (polystireen float / micro switch at the base of washer) in case of a fault (blocked pipe / leak etc).
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
