My Lg too load washer model #wt5270cw - sprays water during spin cycle and does drain the water but the time stops and the clothes are left soaked. I tried doing a spin only cycle & it again continues to spray water. How can I fix this issue?
I was also looking for a similar answer
It is normal for a washer to spin and spray fresh water over the clothes during rinse period. I don’t know why it would leave clothes wet. Look at your options. See if you can turn off rinse n spin to just spin.
Testimonial: "Not the rinse period the spin cycle"
Not during the rinse period. It’s during the spin cycle where it’s only supposed to be spinning until the time is done
A washer will spin twice in a normal cycle. Depending on the brand name, the first spin will not spray water. Top loading Whirlpools will spay water on the final rinse period only. The first spin has large amounts of suds and soap. If it sprayed water, it would over load the motor. The final spin has far less sudds therefore better able to extract the extra spray water. Many people think re-spinning a load will drain more water so drying time is reduced. Their wrong because the washer will spray water and spin it all out. You are rinsing better not extracting water better. The last 4 or 5 minutes of spin time, no water is sprayed.
