When I am sewing my Jean fabric it's not tight it's loose how can I fix it? I have tried the Tension knob but does not seem to work or fix it or make it tighter.
Check you have a needle appropriate for the denim and thread diameter. For denim, a 100/16 or 110/18 needle are recommended.
With threading tension issues, first you start by checking the bobbin tension and once that is set correctly, everything is done using the top tension dial. This is explains in text article
What is Perfect Sewing Machine Tension? Perfect sewing machine tension occurs when the top and bottom threads are perfectly balanced. That means you shouldn't see any little loops on either the top or bottom of your fabric and the stitching should look even on both sides.
Sewing Machine Tension - Top 10 TIPS - Treasurie blog
The two top videos are excellent at explaining how to set bobbin tension, and how to diagnose where the issue is, top or bottom?
https://www.google.com/search?q=sewing+machine+tension
