My Kenmore 80 series dryer is no longer heating up. The dryer it self is running, we have been able to air dry the clothes, but no heat
If all controls seem to work normally, except that no heat is produced (and is an all electric unit--not gas), then likely the heating element is burnt out (has a break in the wire that heats up and glows, like in your toaster--though the heating wire can sometimes be within a covering metal like your electric range burner, and the break not visable). This is a commonly replaced part; it can be tested for continuity (no break in the wire) with a VOM (Volt Ohm Meter--$2 w coupon at harbor freight this week I noticed) where you set to ohm-resistance (to arrow with + sign if shown and will beep when probes are touching to show a complete circuit) (number would be the same as probes touching, but since resistance wire [to make the heat], there will be some number but not close to that of leads just held not touching anything) or the piece of wire, flashlight bulb, and flashlight battery test (casing of bulb to end of element, battery to end of bulb, piece of wire to other end of battery and on to other end of heating element), where if bulb lights then no break in element (though occasionally wire break can be disconnecting only when large dryer current is applied).
Of course unplugged when do all this testing.
The dryer "working" as it is, is using 110 volts (the controls and the motor) and is separate from the heating circuit which is using both 110 volt sides of the outlet, to equal 220 volts.
Of course, you should check that the connections are solid, and if you have the VOM, you could even use the VOM set to 600v AC to check that the outlet is delivering 110v on both sides of the plug and 220v between the two hot leads (usually black and red, with white the neutral which eventuall connects to ground--if a 4th lead, it is the cabinet ground--usually green or bare).
... and make sure when looking in the cabinet, that there is no build up of lint which can cause the overheating and heating element failure in the first place.
