I have a dometic 2200a fridge that works on 110v but not on gas or 12v. Why?
No problems lighting the gas burner, and the tower (?) runs hot, but the fridge will not get cold (also will not work on 12v). The fridge works great on 110v.
Any help will be appreciated.
SOURCE: Dometic DM 2862 Too Cold Freezing Everything
don't worry! just switch off your refrigerator for 8hrs than switch it on......place the thermostart at 3 point......i'm sure that your problem will be solved. if not than replace your thermostart..................have a nice day:-)
SOURCE: dometic rm 2607 makes a gurgling sound when
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
