Hi everyone, I'm looking for insite on this board, I have taken pictures of it, I don't know if this burnt spot on the board indicates its burnt out, the name of the tv is Samsung and the model number is UN46EH5000FXZA and version number is UD03, any feedback will definitely help me. Thanks
Where did you post the picture , it isn't here for us to see.
This link might help: https://www.google.com/search?q=Problems+with+diagnosting+problem+with+tv+power+supply+board%2Fbacklight+board&bih=625&biw=1366&hl=en&ei=PIbQYJb8ELLXrtoP58OKwAU&oq=Problems+with+diagnosting+problem+with+tv+power+supply+board%2Fbacklight+board&gs_lcp=Cgdnd3Mtd2l6EANQpdULWKXVC2CJ2QtoAHACeACAAZICiAGCA5IBBTAuMS4xmAEAoAECoAEBqgEHZ3dzLXdpesABAQ&sclient=gws-wiz&ved=0ahUKEwiWipWi3ajxAhWyq0sFHeehAlgQ4dUDCA4&uact=5
Hi ,
Power on the unit in the dark room then aim a bright flashlight directly to the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing
B+(supply voltage) coming from this board feeding the inverter board. This is
caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible
resistor.
2. Inverter board - even
the B+ is good from the power supply, if the fuse, driver transistor, driver transformer
is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Hi memom440,
Power on the unit in the dark room then shine with the flashlight directly in
resistor.
problem.
Hope I helped you.
Have a nice day!
