20 Most Recent
Vizio VX32L Television Questions & Answers
The orange light is not on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
The orange light isnt on
Make sure the power plug is secure both to the TV and the wall. Also make sure the outlet is not on a switch. Try and unplug and plug the TV back in. Try a different power outlet. Make sure you are pressing power on the TV itself as the remote may not be working. Otherwise TV may need service, and for this unit I would recommend just replacing it to save cost and frustration.
