Televison & Video Logo
Bobby Albin Posted on May 19, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get this viore tv to come on on the hdmi setting? The cable is plugged into to the hdmi and the TV is on channel 3 but all I get is the static screen. It was working but I accidently pushed one of the buttons on the side now it doesn't work.
ADMIN Andrew
Level 3:
Top Expert:
  • Viore Master 66,980 Answers
  • Posted on May 19, 2021
ADMIN Andrew
Viore Master
Level 3:
Top Expert:
Answers
66980
Questions
Helped
5090088
Points
379943
You don't want 'channel' 3, you want 'source/input' 3. Check the remote for Source, or Input..
5 Related Answers
Anonymous
  • 3614 Answers
  • Posted on Feb 18, 2008
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Anonymous
  • 206 Answers
  • Posted on Mar 06, 2008
SOURCE: TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Michael Borelli
  • 979 Answers
  • Posted on Jul 01, 2008
SOURCE: no channels
Are you using a set-top converter box?
Anonymous
  • Posted on May 13, 2010
SOURCE: Blank Screen using HDMI-DVI cable for PS3
i have my ps3 settings on default settings but i no longer have my red yellow white cords, just the hdmi cord. i need guidance setting it to hdmi on a blank screen
Anonymous
  • Posted on May 22, 2010
SOURCE: no channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
My viore tv Scans Ruf channels but won't scan digital channels. Power went off it lost all over the air channels
If your Viore TV is unable to scan digital channels after a power outage, there are a few things you can try to fix the issue:
  1. Check the TV's antenna connection: Make sure that the antenna is securely connected to the TV and that there is no damage to the cable.
  2. Rescan for channels: Go to the TV's menu and select "Auto Tuning" or "Channel Scan" to rescan for channels. Make sure to select the option for digital channels only.
  3. Check for software updates: Make sure that your TV has the latest software updates. Go to the TV's menu and check for any available updates.
  4. Perform a factory reset: A factory reset will restore your TV to its original settings. This can sometimes fix issues with channel scanning. Consult the manufacturer's manual for instruction.
  5. Check your TV's location: Make sure that your TV is in a location where it can receive a good signal. Try moving the TV or the antenna to a different location.
If none of these steps work, it's possible that the TV's tuner may be malfunctioning and may need to be repaired or replaced. Contact the manufacturer's customer service or a professional technician for further assistance.
Regenerate response
How to connect laptop to flat screen TV
You can use a VGA cable to connect to your flat screen. Then select the RGB input your tv and it should work. If your computer is new and high end enough it may have HDMI out and then I would use an HDMI cable.
2answers
The TV works however I cannot get the set to read the channels. I have cable but no cable box. Have tried to program it for over 3 hours. I've tried it using ch.3 and ch.4. through the remote. After I scan...
U used the tv remote go into ur tv SETUP.Pick Cable,before u scanning for cable chanels?U have pay cable?Must scan for cable chanels,by setup for looking for cable channels.
What source and channel does a viore tv have to be on to work?
it depends on how its connected to the cable box
Coaxial (regular cable wire only) channel 3 or 4
RCA Jacks (Yellow, red & white plugs) check the back of the tv for the connection usually Video 1
Component cables ( 5 wires) Component 1, or colorstream on older models
HDMI HDMI 1
2answers
My hdmi connection wont stay on on my vior plasma 42 inch
You may have used Monster cables which can expand the plug in the TV.
Sorry, but you'll need to get a new input or use tape to hold it in.
When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
113helpful
9answers
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Top Viore Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
