20 Most Recent Viore 37 Class LCD HDTV Questions & Answers
look for aspect ratio
that should fix it
Viore 37 Class... | Answered on Jan 12, 2016
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Viore 37 Class... | Answered on Sep 27, 2015
Push the source button again and again, since the desired input is selected. Gopakumar Gopalan Google
Viore 37 Class... | Answered on Aug 09, 2014
You must have a 1080P signal running to the TV. Other wise you can't.
Viore 37 Class... | Answered on Apr 27, 2012
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD
Viore 37 Class... | Answered on Apr 01, 2012
The player has failed, i suggest you replace it with an external player, they are dirt cheap.
Viore 37 Class... | Answered on Mar 23, 2012
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://elektrotricks.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Viore Televison... | Answered on Jun 04, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview]//
Viore Televison... | Answered on Oct 27, 2018
Viore 37 Class LCD HDTV Logo
Popular Tags
11 questions posted
Top Viore Televison & Video Experts
Tom Chichester
Marvin
Marvin
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Viore Televison & Video
Most Popular Question
viore tv permanently zoomed in want out
  • Televison & Video
