I reset it but it still doesn't work
SOURCE: cold air coming out car heater, turn heat up to 90
check water level in rad if ok check thermostat or couldbe a plugged heater core.also check for vacum to heater door is working
Posted on Nov 21, 2008
SOURCE: heater dosne't put out warm air
check fluid level in the radiator.If thats ok could be the thermostat.
Posted on Nov 12, 2009
SOURCE: I have a blue flame GLO WARM 20btu wall model # WMP20A
Look for and clean the flame sensor.
Posted on Dec 06, 2009
SOURCE: 2002 eclipse heater blows cool air
Check your antifreeze level and if low then add antifreeze until the radiator is full and the overflow tank is up to the correct level. that should solve your problem. If it isn't that, chances are your thermostat could be stuck open which isn't allowing the coolant to warm up properly.
Good Luck
Posted on Dec 19, 2009
SOURCE: 04 gmc yukon heater air cold passanger side.
If this happens when you are idle, and then you get hot air as you drive, most likely you have low coolant and it only cycles as you drive. Get approved dextrom gmc coolat and cap off your coolant it is most likely low.
Posted on Jan 21, 2010
Dec 10, 2016 | Heating & Cooling
Mar 24, 2016 | Duraflame Portable Tower Electric Heater
Jan 10, 2016 | Heating & Cooling
Nov 30, 2013 | Dimplex Compact Electric Flame Stove...
Aug 27, 2013 | Heating & Cooling
Feb 20, 2013 | Duraflame Heating & Cooling
Dec 31, 2012 | Heating & Cooling
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Jan 18, 2011 | Rinnai Toyostove Direct Vent Heater:...
Jan 21, 2009 | Coleman Propane Forced Air Heater...
14 people viewed this question
It's a electrical heater
