Heating & Cooling Logo
A
Anonymous Posted on Feb 20, 2013
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Jimm
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 26, 2015
Jimm
Contributor
Level 1:
Answers
Questions
0
Helped
3316
Points
0
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
4 Related Answers
Lou Barta
  • 189 Answers
  • Posted on Mar 28, 2009
SOURCE: The Heater is only blowing cold air
I would need a lot more info. if this is a natural gas furnace you may have a bad hot surface ignitor
Anonymous
  • 6 Answers
  • Posted on Oct 06, 2009
SOURCE: Heater turns on, and I can see flames but cold air
check filter is blower on at all return duct open vents open
Anonymous
  • 185 Answers
  • Posted on Feb 02, 2010
SOURCE: DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Paul Carew
  • 3807 Answers
  • Posted on Feb 09, 2010
SOURCE: heater blowing cold air light on heater flaseing 4
the limit switch works on temp rise and temp fall , limit switch could be dirty on the sensor clean this and see if this hepls
Duraflame Heaters won't blow?
Question edited for clarity and translated into written English :>D
Question recategorized from Laundry Dryers to a Duraflame one.
It could be the blower.
It could be the thermostat.
It could be the element.
It needs testing by an appliance electrician. If you have a multimeter and the skill, you could do preliminary testing yourself.
Also, they make many models of heater. You could Google
Duraflame (model) no heat no fan.
'Dura Flame' all one word, I corrected that too.
Why does it just blow cold air?
it blows cold air because the flame hasnt ignited. You are having an ignition problem due to either an unsatisfied pressure swith and a burned igniter. Have a look in the burner ports for the entire cycle and look to see if you can see e bright orange glow. if you dont see it, check your venting for blockage and also maybe the condensate drain tube for blockage
Auto theft device on and car will not start Infiniti G35
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Heater not working
13helpful
2answers
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
1helpful
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Top Duraflame Heating & Cooling Experts
Paul Carew
john h
Are you a Duraflame Heating and Cooling Expert? Answer questions, earn points and help others
