Vacuums Logo
r
robert vermillion Posted on Sep 02, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hoover Windtunnel uh30010 - check bag light and blue light flashing
David Spradling
Level 3:
Top Expert:
  • Hoover Master 13,524 Answers
  • Posted on Oct 24, 2020
David Spradling
Hoover Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929644
Points
28396
Possible clog in hose
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
I have uh30010 hoover that stops and flashes when handle tilted
I had one in doing this last week. I replaced the upper handle and it acted normally again. Maybe just a bad connection where the handle plugs in?
This is the part I'm speaking of:
http://www.vacuummedic.com/product.php?id=389
Good Luck
I replaced the handle on my Hoover UH30010 Platinum Bagged upright and now the check bag light is on and vac will nut run.. Is there a reset button? How do I fix this?
Hey. I believe you will need to replace the main PCB board too. My new handle was sent with a new PCB board. However, I tried just replacing the handle first and it acted the same way you describe. Once I changed the PCB board it worked fine. Hope this helps.
I need a new bag for the Hoover 3.8 Model # U5465-900 which bag is it ?
Hoover Genuine Hoover Type Y Allergen Filtration Vacuum Bags, Fits Hoover Windtunnel and Hoover Tempo Bags Hoover 4010100Y
Windtunnel hoover is not suctioning but blowing instead
look near your bottom of your vacuum. it might be clogged there have it looked at a soon as possible.
WIndtunnel TurboPower U5400-900 sensor light flashing even though I just changed bag
they do this as a matter of course. its a poorly designed vacuum. Hoover doesnt exist any more, it is actually a dirt devil
after years in the vac repair business, i reccommend that you look at panasonic the next time
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
