How do I replace the bulb housing in my sony dlp tv. Its a 55'' tv and it houses the sony lamp xl2400. Please help with this issue... I can't find instructions for TV..
Re: how to install a SONY LAMP XL2400 into your TV
Remove 2 screws from bottom back of tv(plillips) now carefully remove front cover.it unclips,sometimes you have to pry it off.take out screws from lamp cover,remove cover,take screws out of lamp, remove lamp.reverse process to put it back together.
For Part Number: Sony Lamp XL-2400 ( Sealed
replacement lamp for televisions, SMALL & SEALED ). Compatible Part Numbers: XL-2400,
XL2400, XL-2400U, XL2400U, XL-2400E, XL2400E, F93087500, F-930-8750-0,
A1129776A, A-112-9776-A For Enclosure: Sony Lamp (
XL-2400 / 2-590-738 ). Television Type: 3LCD. For Bulb: UHP 120 /
100w 1.0 E 19.8
Philips UHP 120 / 100w 1.0
E 19.8 1.0 Philips.
The blinking light is typical of a failed lamp and they last commonly between 2-5 years tops in these sets. You should replace the lamp. The link below is to the lamp for your set.
You can get them from many places but you want to get the lamp with housing most places only sell the bare lamp annd then you have to install the new lamp into your housing being careful not to touch the lamp . You can get the Sony XL2400 lamp with housing from www.tvrepairworld.com which is 159.00 and includes installation instructions which takes about 2 minutes and no special tools required when you get the lamp with housing as an assembly.
Your model uses the sony LAMP WITH HOUSING XL2400 F93087500 you canget the lamp with the housing from www.tvrepairworld.com which comes with step by step instructions its 139.00 installation takes about 2 minutes and no special tools required except a screwdriver. Its llisted under SAony DLP Lamp catagory
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
