SOURCE: Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
SOURCE: how to record from a cctv camera to a digital tv recoder
You can't do this at all. It will only record from its own freeview tuners.
SOURCE: Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
SOURCE: my DVD recorder LG RH1858 isn't recording
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
