SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
SOURCE: I hooked up a rca digital flat antenna and cant get any channels it just stay on channel 3
check the settings in your tv .
