Replace the LED strips: https://www.shopjimmy.com/sharp/lc-39le551u
SOURCE: kls-320ve-j inverter/backlight board
If you have to ask these questions then you should leave it alone. The high voltages produced by this board are LETHAL ;)
SOURCE: Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
SOURCE: I have the same power supply problem on my
You may be able to repair the board instead of buying a replacement board. If you are up to a little soldering it may save you a good bit of money for the repair. If you are interested just take a few pictures of the boards and email them to us at [email protected] We will check them out and give you some pointers on what to do. Most power supply issues with the blinking power lights are caused by blow capacitors on the power board. These are fairly easy to replace and the replacements are less than $20 usually. To get an idea what capacitors are and what will need to be do to repair you unit check out our pages at :http://www.ccl-la.com/blog/index.php/capacitors/ You may want to look over the repair guides for other units we have posted too. If you need parts we can also supply them for you. If you have any additional questions just contact us at: [email protected]
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
SOURCE: Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
SOURCE: KDL55HX800 dims and then shuts off and red LED blinks 6 times
IIC bus clock and/or data lines low at power on 06
